Burning tons of oil
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
If it ain't broke, fix it 'till it is!
I'm thinking its the valve seals, any other ideas?
coffee
Buena Vista, Ga.
Have you done a compression test? What do the plugs look like? Got leaks along with burning oil?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
If your motor has a lot of miles on it then it is probably the valve seals. They are know to wear out when the motor gets high on mileage.
