Building a bronco II
doallthingswell
I have the following
302, carbureted
AX-15 trans (best I could do)
NP-205
1977 full width D44 HP lock to lock with radius arms, radius arm brackets, coil buckets, shock mounts, steering parts... all of it from a 77 F150 ranger with factory quad shocks.
Matching 9 inch rear.
I have all of the tools. Alot of previous 4x4 experience with everything but dodge.... lol
This includes a milling machine a lathe a hydraulic press a tube bender a MIG machine an arc welder a plasma cutter oxy acetylene torch all of the goods to go with it and plenty of hand tools..... I'm set up honestly....
Now i need a BII/Ranger/Explorer ... older the better I suppose.... and guidance... helpful links are appreciated... I have USED SEARCH :) be proud!
That's how I got this far [emoji51]
... the elusive C-4 trans leads me to the AX-15 and Novak conversions... [emoji19]
Again ANY pics/links/advice is nice.
All these parts need a home!
Sent from my SM-G920V using Tapatalk
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
So there are lots of Broncos, Bronco II, Rangers and Explorers around to acquire or have you not started your search yet. The one that,s gonna cost the most is the early Broncos, people are crazy when they start pricing them out, even the ones that are POS,s. But it sounds like you have a lot of nice stuff to go with if you find the one you like. Good luck and post lots of pics.
