dispatchrobb
- Sep 15, 2011
- 0
- Ford
- Engine Size
- 2.9
2.9L B2 won't start. It runs fine, but sometimes the amp gauge shows low. Today it turns over but too slow to start, but the battery just keeps turning it over so I know that's not totally dead, however, when this happened before, I jump-started it and it spun over much faster than normal and fired right up on the first crank, and didn't happen again for a couple months till today. It's been firing right up so far.
KOEO codes are 1-1 and the second set is code 15 which is Failure in ECA,problems with keep alive memory.
First, is there a speed that the engine must spin for it to actually start? Autozone said my alt and batt are fine, but something doesn't seem right since it pulses 3-4 times after I start it up, then everything gets bright but the gauge sometimes reads lower and there's really no rhyme or reason it does, sometimes it doesn't, sometimes it does.
I only drive about 5 miles to work so maybe the batt isn't getting charged back up fully with a possible bad alt, and it's just to the point where it won't start it up but I can if I jump start it? I also have a Lincoln electric fan, set up through two marine relays on a manual switch. I haven't needed it till recently, so maybe that's drained the battery and the faulty alt can't charge it up in the short drive to work? The amp gauge drops a ton when I click it on but comes back up in a second or two but reads lower than normal till I turn it off.
