Bronco II 4 speed HELP
Lockwood BII
I just swapped in a 4 speed out of a ranger due to my 5 speed being screwed.
the problem now is the stock driveline is too short. I need at least a 34" rear. is this stock to the ranger? and i can just pic n pull a driveline?
84bluebronco2
13
Central New York
I have an 84 b2 with a TK4 4speed. The shafts are all different depending on the transmissions. I know the only ones that I've heard to be plug and play are FM146 and A4LD. All the rest seem to be an inch this way or that way. I was planning to swap an FM145 but the shafts are different. Do you have access to the truck the TK4 came out of? (assuming it is a TK4)
Ranger an B2 don't share a rear d-shaft for ANYTHING. The wheel bases are very different. Go find a 4-speed B2 and grab the rear shaft, or go find a driveline shop and get your's lengthened.
