Bronco II 2.8 L will not advance
John R
I have a 1985 Bronco II 2.8 L 4x4. The engine has about 8000 miles. Transmission went out and it sat 6 months. Just put a new transmission in and it will start and idle just fine but when you press the accellerator the electronics module will not advance. The carb has been cleaned and fuel pressure is fine. Any ideas? Is there a throttle position sensor or something that may not be relaying information to the electronics module? Any help would be appreciated!
voodoochylde
Rainelle, WV
2.9l
Have you tested the TFI ignition control module (or had it tested by a parts store)? I'd start there but I'm not so hot at this lol. Maybe someone else has a better idea.
martin
26
St Bruno, Quebec
1991
The connector for setting the timing (can't remember what it's called) might have broken or become disconnected when the transmission was changed.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Spout connector.
The computer advances the timing but what tells the computer to advance it is the TPS. You press on gas pedal, it tells the computer that engine will be increasing in speed and to advance the timing (along with a few other things).
MUNCHER
Guest
ecm
You can uplug that ecm it it will run fine ive takin them thing out for years and never had any proablems. all that is for is smog.
dangerranger83
54
Lafayette, IN
The computer controls the advancing/retarding of the timing and the carbs on these trucks. Just unplugging them will not fix the problem, it will create more.
If you wanna eleminate the computer system, duraspark it if your state doesn't do emissions testing.
jhammel85
Guest
^ +1. Alot of people do it here so there should be plenty of write ups if you want to try it.:icon_thumby:
Hotrodlincoln
The yellow (I think it's yellow anyway) single wire from the distributor is on the right (passenger) side of the engine back near the firewall. It has a black connector about 8 inches from the distributor which you unplug to set ignition timing. If that wire isn't broken or unplugged, do a Duraspark swap (look in the 2.8 section of the Tech Library) because getting that EECIV management system to work right is a royal pita.
RUTH
September 2010 OTOTM
NMB2 has a 2.8 in his b2 truggy... maybe pm him to see if he could help out... hes very knowledgeable..:icon_confused:
The_Dealer
10
Macon, GA
Duh!
i had to duraspark mine, was missing alot of stuff and mine wouldnt advance either. tfi hit the valve cover when i tried to advance it, didnt want to take out the tfi one and reset it in there so i d-sparkd it, and man was it worth the money. take your time and make sure your wiring is right. i got everything new from advance for about 120 bux, burnt up the coil so another 28 bux for a summit cannister coil. but i had it wired up wrong the first 2 times
