Bronco 2.9 wont start need help
hillvalleybronc
My 89 bronco 2.9 shut off on me today going down the road. The fuel pump is running but i have no fire. Changed out the coil from a working 2.9 and it didnt help. changed the ignition module and that didnt help. changed computers and that didnt do anything. I have no fire what so ever. Im running out of ideas. any help would be appreciated..thanks
kimcrwbr1
46
maplevalley WA
2.8l
check all the grounds sand metal to metal especially coil to engine and are you getting power to the coil from the ignition in run and start also look for power to the dizzy look in the tech library under TFI
kimcrwbr1
46
maplevalley WA
2.8l
Also do you hear the EEC solenoid click when you turn the key to run try changing the computer power solenoid.
kimcrwbr1
46
maplevalley WA
2.8l
Is the rotor turning as you crank the motor
hillvalleybronc
Wheres the eec solenoid? yeah the rotor is turnig.. there is power on both sides of the coil. I sanded the ground on the coil.. I still havin nothing.. changing the disturbtor now..thanks.. what a headache..
master hec0
5
okotoks alberta canada
4.0L V6
have you tested for spark? 1st off test for spark then check to see if you are getting fuel to the motor. after cranking for a bit remove a spark plug and see if its wet with gas. could also be timing but i doubt it.
John Smith
6
pull the coil wire and
check the fire as you crank....also is the engine harness grounded at the coil mount ?....mine had to be...
also
if comp can't get the pu sig from dis...it doesnt know the engine is cranking..and will not flow the fuel....
kimcrwbr1
46
maplevalley WA
2.8l
The computer solenoid is either by the computer on the passenger bulkhead or by the start solenoid or in the power dist box under the hood if you have one. yea that hold down bolt is a biotch. were you getting power to the distributor key on and in the start position I believe it is pin 4 and 3 let me check
kimcrwbr1
46
maplevalley WA
2.8l
To check the coil put a spark plug in the coil wire off the dizzy then ground the plug and turn the ignition on, take a jumper wire from the neg or green wire on the coil and quickly touch it to a good ground the plug should fire if you get spark then go to the dizzy wire connector and jumper coil neg wire to ground if you get spark the circuit is good from the dizzy. From personal exp same symptoms was a bad coil and EEC relay the TFI just made it run like crap but never had the PIP coil go bad either.
hillvalleybronc
FIXED!!!! Thanks everyone...good to go til the next time..
xr75er
7
ford/dodge/ford
2.9 stock
Fixed? what did you have to do? lots of sugestions, did any of them do the trick?:icon_confused:
hillvalleybronc
just was a bad connector where the ignition module plugs into the wiring harness. thanks
hillvalleybronc
when i checked the plug the red/green pin in the connector was burnt/off, missing completly.
