Bronco 2 302 conversion with granny 4spd
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
thats the answer I was looking for....will post a build thread soon...thanks again
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Dont know if there is a difference between masters but what is on my truck is one from an 85 ranger that use to push an internal slave. My truck is an 83 that use to have an external before I put a 2.8 in and the only complete setup I could find was out of an 85 at my local jy.
My clutch releases right where it should but is a bit harder to push but nothing you don't get use to. I'm also running a 10 inch clutch or one rated for under 8600 lb truck or something like that.
Sent from my rooted SPH-D710 using Tapatalk 2
buell-eyed-devil
21
FORD
5.0-ZF in process
guess this idea fell into the dumper. Not getting the 4speed so I guess the c4 is back on
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
What about going with a ZF, best of both worlds with an overdrive...
SVT
dangerranger83
54
Lafayette, IN
SVT
If I have to get a new trans, this will be my next one.
buell-eyed-devil
21
FORD
5.0-ZF in process
what does a ZF come in? Dont know anything about them but will give a listen...Thanks a bunch...Btw, motor mounts came in and am currently finishing up the motor.. Drove my son in laws SVT Focus on a 2 hr trip and remember now why I have automatics. Also got some block hugger headers from Summit that will hopefully work.
dangerranger83
54
Lafayette, IN
I would never cover my truck to an auto, manual is just to much fun.
The zf can be found in f250s and maybe other ones. They are big and will want a body lift.
buell-eyed-devil
21
FORD
5.0-ZF in process
ok, here is my update.got a 4spd (mid eighties) no transfer case. Today the guy that gave me the 4 spd says "I have the auto trans/ transfer case out of an 82 Bronco you can have".My question is this, Will the 4 speed bolt up to the transfer case that is with the automatic? I wont have the pieces until the weekend or I would just try it. Anyone know?
buell-eyed-devil
21
FORD
5.0-ZF in process
guess I should post some pics...84 Bronco 2 new body mounts and 3 inch body lift. Currently sitting on 35 baja claws rear and 34 super swampers front
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
We need more info, but unless its a dana 20 tcase, which is unlikely, it'll bolt up to it...
SVT
buell-eyed-devil
21
FORD
5.0-ZF in process
dangerranger83
54
Lafayette, IN
Sounds like an np435 trans and the np208 will bolt to it. Same setup I have in my truck.
Sent from my SPH-L710 using Tapatalk
buell-eyed-devil
21
FORD
5.0-ZF in process
ah sweet...I like your truck.Hope to post some pics this weekend if it don't rain
dangerranger83
54
Lafayette, IN
I did my swap during the hottest summer on record and what did it do...it rained mid way through it yet for almost a month it didn't rain.
buell-eyed-devil
21
FORD
5.0-ZF in process
going with my son tomorrow to get all this stuff, then Sunday if it doesn't rain maybe hit the junkyard
