Brand new pump(non-refurb), but still whines
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
In my 1992 ranger with 110,000 miles on it, I decided to replace the PS pump since it was whining really badly. I replaced it, got all the air out of the pump and topped off the res. The thing still whines a little bit.
Would a new steering box or something correct the issue? I thought it would all be in the pump, but with a new pump, it still whines under load.
Any ideas?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Sorry to say, but its pretty normal.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Iron Ranger
MTOTM Winner
22
Minnesota
0.040 punched 302
scrapper
63
central IL
1975 302
I had a 79 f-100 that started making noise and was told to put trans-x in it and it worked great. only added about a 1 inch in the tank and moved wheel back and forth very fast then drove around and it got quite and worked great.
Mazda
11
Temecula, CA
Mazda
2.3
You put Trans Fluid in it right. When I changed mine it took about a 1,000 miles to get it quiet. From your Sig I think you have a 4.0 but if you have a 2.3 like me might want to change the pressure switch to. Helps with idle and probably will get some whines out with the right pressure when you move the wheel.
DFracing
welcome to owning a ford lol
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
*gasps* NO!!
I've gotta try this...soon.
