akulczycky
- Aug 25, 2009
- 0
- Ford
Brake Line Fitting Question (97' 2.3L)
I put in all new brake lines, using the polymer coated ones from NAPA, and I connected most of it, unfortunately, I think I got the wrong fitting to connect to the master cylinder, and may have stripped the hole there. This has made me somewhat concerned about the other fittings (haven't tightened everything yet) and I wanted to see if anyone knows the size fittings I should have, so that I make sure I don't damage anything else.
97 Ranger, 2.3L 4 Cylinder
I currently have the 3/16 standard US fitting line (that's what the tag said), what are the fittings for these lines:
Master Cylinder to Driver Side Brake Hose
Driver's side to Passenger's side
Master Cylinder - the ABS controller (I think that's what it is)
ABS controller to the Rear brake hose
Rear Brake hose to Rear wheel (L/R)
I figure if I need to, I can get the adapters and save myself the potential damage of making things fit, whether they want to or not!
If anyone knows, it would be a tremendous help!
