Brake lights
b2rich
Lake Oswego, OR
whats an engine?
My break lights don't work.
Turn signals, 4 ways, driving, reverse all work.
I replaced the switch. No difference.
In the past I heard the switch click as I depressed the break pedal. Not now.
Any ideas?
Sam_Ranger
Laredo,TX
2.3
Get a circuit tester or a volt meter and go from there. obviously there is not voltage at the back end. so check right after switch.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Unplug the wire harness from the switch. Take a short piece of wire or a paper clip and short circuit the two terminals. If the brake lights light up, the switch is bad.
AaronC47
Pacific NW
94
Mazda
No BRAKE lights,,,,,,
Have you checked the brake light switch under the dash ? When you hit the brake pedal you allow the switch to make connection and thereby turning on brake lights. You can put a jumper wire between the 2 contacts and they should come on.
Just in case you didnt get it fixed yet, I thought I would respond.
