bouncy oil pressure?
bcost882
5
The Queens Country.....
3.0L, 1.6L
well i started my truck up after work today and the oil pressure took a sec to pop up. then after it did it popped down after about 2 seconds then popped back to the middle then had a couple minutes of retard where it was twitching from just below the middle to just above the middle. I've had problems before where my oil pressure pops up and then down then back up after i started it but not the twitching. Is it maybe the pressure sender? i know it is a dummy gauge and shows the middle no matter what pressure as long as it is over a certain amount.
Big Jim M
30
Austin
Maybe you are correct.
Big Jim
Joe_Roofer
Berkshires, MA
1990ish
My 99 exploder just started doing the same thing, goes from 0 to the middle several times fast, then stays in the middle.. I'm thinking pressure sender too.
ranger1996
55304, minnesota
my 96 ranger has been doin that for about 2 weeks now. i'm probably going to replace the sender. im not gonna mess around with the gauges unless it still has issues
bcost882
5
3.0L, 1.6L
It just looks like a pita to get to the sender it is right behind the right valve cover right?
Rochester, NY
3.0 Litre Flex Fuel
it looks gold in color and i believe most of them have a white plug, and its on the right side on the back of the engine, pretty easy to change, mine was doin the same thing and i changed it and it fixed the problem easy.
kimcrwbr1
46
maplevalley WA
2.8l
Try cleaning the connector and crimp it a little so it fits on tite sounds like a loose connection to me.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
if its not the sender it could be the oil filter, or a plugged oil pump pickup.. im assuming your engine is not making any noises.
i have had BOTH of these things cause the gauge to twitch.
kimcrwbr1
46
maplevalley WA
2.8l
Always put dielectric grease on your connectors when you put them together to protect them from corrosion.
