Blowing O2 Fuse
Rustbucket350
32
2000 Ranger 2.5. When I turn the ignition on it'll blow the O2 fuse in the power distribution box immediately. I unplugged everything on that circuit and it still blows. However, if I unplug the large plug between the power distribution box and engine harness/pcm it doesn't blow the fuse. I'm not sure if it's a wiring short or a pcm issue.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Have you considered pouring your truck a cup of tea and asking it what's wrong?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
In all sincerely, it sounds like a short, but I have no idea.
Someone far more knowledgeable than I will be along.
RobbieD
2.9l Mafia
3,579
Georgia
Harness going to the sensor may have come loose and melted on an exhaust pipe. Worth crawling under and check the wiring.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,597
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Did you R&R the engine or transmission?
Pinched the harness between the two?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Rustbucket350
32
I checked the harness for burns but didn't see anything worth cutting the loom open. I'll have to take a closer look. No wires are pinched and it just randomly started blowing the fuse out of the blue. I was hoping for a way to isolate the pcm or harness to narrow it down further. Not sure if it's even possible to test the pcm.
Rustbucket350
32
Well I found that one of the two grounds on the firewall by the pcm had a short somewhere invisible. Ended up just unhooking it and everything seems to work fine with no codes. I can't explain it and I have no idea what that ground is for.
