Blowin out header gaskets ?
ATX
11/2014 MTOTM Winner
MTOTM Winner
Austin tx
Built not bought
So I'm so tired of blow out gaskets on the passenger side flange . Flange is thick and seems to set flush from the naked eye but has to be some what warped or the header bolt holes are not large enough and hitting the sides of the flange when tightened down . I've checked length since I've replaced half the bolt with chevy bolts do to falling out over time . I've locked tighted everyone since then and re tightened. I don't have flex pipes yet and so the exhaust is pretty stiff including mounts . Anyone else have this kinda issue and figured out a solution that worked .
Ive been using paper and composite type gaskets and even doubling them up . Today I saw a set of solid aluminum gaskets . Mr gasket 7401g anyone use them . There $30 so I may just give them a try and see
faststang90
dayton texas
ranger
347
I use copper ones for years with out any problems and I have pulled the headers off a few times
ATX
MTOTM Winner
Austin tx
Built not bought
Well bought the mr gasket 7401g . $25 installied last night in the rain . Hasn't stopped for 2 1/2 days now here in central Texas . Feel for them on the coast
ick
Mesa AZ
I use remflex gaskets and like them. I think they have a warranty/gaurantee.
Sent from my SAMSUNG-SM-G930A using Tapatalk
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
Using paper style gaskets on exhaust are not very robust and doubling them is just more layers to leak between.
I always use metal exhaust gaskets on all my custom car builds and have never had any issues doing so.
Although the mustangs guys seem to use the Remflex graphite gaskets pretty commonly with success, the Trickflow/Cometic Steel gaskets or even just copper rtv by itself.
I have the Trickflow/Cometic multilayer steel set for my motor but the truck is not on the road yet, so I can't say how well they seal.
But on a steel block and quality Metal or maybe a Remflex gasket if you end up still having issues I would suspect that the header flange is not a 100% flat and maybe you should have them checked and if needed machined flat to make sure before hassling with having to replace gaskets multiple times.
mavereq
Concrete, WA
Have the flange machined flat. If you're blowing head gaskets that much on a non turbo setup, you might have too much restriction in the exhaust. Had a 460 keep blowing gaskets until I removed the cats.
ATX
MTOTM Winner
Austin tx
Built not bought
It 2.5 straight pipe from the tri-y's back to flows exited before the back tires out the sides . Think I need to go to 3" ? It's a stock 96 5.0 expo with just headers, cats deleted and home Cai . Sucky thing is I can't remove the headers with out either cutting them out like I did to install or removing the engine . They double paper idea was a coworkers that did it to his sbc so we tried . Worked longer the expecting the air blowing out this last time . I've tried the graphite composite set also and same thing . These crush aluminum gaskets are way thicker and solid layers . Could barely fit the gaskets in between the flange in the head . Had to use a lil longer header bolts to get it tight enough to get the others in . So far so good .
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
There is no way that dual 2.5" straight pipes dumped out the sides with no cats is causing to much back pressure on a stock 302, that is plenty of flow.
The new metal gaskets may very well solve your issue, if that doesn't do it then it pretty much has to be warped header flanges. Sucks it would be such a massive task to get them out to fix if so.
Good Luck let's hope this fixes it!
