block numbers question
Dav
26
riverview, fl
ranger xlt
, 2.9
none but it is a convertible
stock
pulled the starter for the sole reason of figuring out what this motor came from. and put it right back in.
there is a tab of steel sticking out that has '78' in numbers about 3/4 inches high.
where all the id sites say the numbers should be are the following, in numbers about 5/16 inches high;
D8VE 6015 A3A
8D1 3
the D8 means 1978
the V does not match any vehicle
E means engine and so does 6015
i think A3A could be ABA in which case the motor is in it's 53rd style. if that's not a B but instead a 3, i haven't a clue what it means.
the 8D1 3 also do not come up in any of the ford id sites i have looked in
so can anyone with the right books or just lots of knowledge tell me what this came out of?
it is hooked to a C-6. since most of the work on this truck is aggie engineering, i have a gut feeling that the trannie is original to the motor. someone used what he had
8,372
D8VE is casting mold number
yes D8 is 1978, but this could be found in a 1981 vehicle if Casting was never changed, but wouldn't be found in a 1977 vehicle(unless engine was swapped, lol.)
Casting number is not the year it was made, just the year it was designed
V = Lincoln(1961-1981)
E = Engine group
Yes, 6015 is generic part number for any Ford engine
A3A/ABA is the revision number, small changes made but not enough change to change casting number, AAA could be no revisions, so ABA could mean just 1 revision
8D1 3 is the date it was manufactured
8 = 58/68/78/88/98, in this case 1978 because of casting number
D = April, i.e. Jan=A, Feb=B, March=C, ect.............
13 = 13th
So engine was made April 13th, 1978 for Lincoln division
Dav
26
riverview, fl
ranger xlt
, 2.9
stock
thanks Ron
since lincoln is not noted for high performance engines, i am going to run with flat tappets and see what the u-pick has for distributors
8,372
You ever try to PUSH a Lincoln?
Any engine in a Lincoln of that era would be high performance by default :)
I tried to push a boat across a parking lot once. Is that at all similar?
8,372
As long as the boat was NOT on a trailer then it would be similar :)
Dav
26
riverview, fl
ranger xlt
, 2.9
stock
strangely enough, i pushed my 58 T-bird convertible on more than one occaision, too many occaisions. it was easier to push than any other vehicle i have owned-except for my bug-eye Sprite. (oh how much i wish i'd kept that bird!)
this leads to the reason for the post; to figure out if i need a dizz with a machined gear or a cast gear. i have a parts motor. if i pull the intake will the tappets be exposed? if so, i could pull a pushrod and measure it against one from the 'good' motor-6 7/8 inches long-, then pop out the tappet and know if it's roller or flat.
yesterday measuring that pushrod was the farthest i've been into a fomoco since 1986.
Yes trailer, no axle.
Dav
26
riverview, fl
ranger xlt
, 2.9
stock
the push rod
from the 'lincoln' motor is 6 7/8 long.
the parts motor has a 6 1/4 inch long rod and roller tappets.
so now i need to confirm what dist i have. progress, albeit slow progress
