BlackBII's white ranger
BlackBII
Ranger Custom
Truck of Month
982
UT
Yeah I have a tube bender now so I am going to make some tube ends and probably a stinger. I will also be adding some rock sliders. :icon_thumby:
I didn't dent it up on purpose! My brake booster vac line came off so I had no brakes, and I went right into a tree. Twice.
DOPIESLC
West Valley, UTAH
Twice? If it's anything like our trip then that's understandable. Did it come off cause of the body lift, making the hose too short?
BlackBII
Ranger Custom
Truck of Month
982
UT
No, although I'm sure the 1" body lift didn't help. My transmission mount broke and so when I would rev the engine under load the whole drivetrain would rotate to the right like 8 inches. :icon_surprised:
This rotational motion of the engine pulled the vac line off the booster and I lost my power brakes. My engine was also revving at like 2500rpm so it was difficult to crawl around slowly(I was turning around to go back down the trail).
I didn't figure out what was wrong until after I got turned around and after I had hit the tree.
It's okay, the ranger will solider on. I just ordered a new poly trans mount. :icon_thumby:
DOPIESLC
West Valley, UTAH
Damn! That little 4 banger broke the transmission mount. Or was that one of the mounts you didn't replace yet? Oh did you ever fix your motor mounts from our trip out?
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Tore out motor mounts on my truck once, tried hooking the vacuum line back up a few times and it kept coming off again, zip tied a piece of duct tape over the port on the manifold so the truck would idle. Finished the trail (all downhill off a mountain of course), hooked the vacuum line up, and drove it home :icon_thumby:
85_Ranger4x4
17,933
SW Iowa
Mine still has the old A4LD mount in it. :shok:
BlackBII
Ranger Custom
Truck of Month
982
UT
Interestingly, I DID replace the trans mount with a poly one years ago, but then I removed it and put the poly mount into my daily driver explorer. So, the ranger just had an old stock mount that was all loose already. And no, haven't replaced the motor mounts yet but I have new ones sitting on my toolbox. So those were likely also part of the problem. My whole drivetrain was moving around like crazy. This weekend or next I will be replacing the motor mounts and the trans mount. :icon_thumby:
Yeah that's basically what happened to me too. Glad to hear I am not alone! :D
BlackBII
Ranger Custom
Truck of Month
982
UT
85_Ranger4x4
17,933
SW Iowa
BlackBII
Ranger Custom
Truck of Month
982
UT
Whoa.... What the hell is this?
Why is the engine back out?
Oh.... broken engine mounts. Of course. :annoyed:
Oh and look at this, the stud on the new mount is too long. Going to have to cut that down :icon_welder:
turbo91xlt
63
Goshen, NY
1992
I gotta do the ones on my black truck. Been putting it off till I'm ready to drop a turbo engine in it either over winter break or summer break. Changing them is such a PITA haha. I did them on my other truck when I put the turbo engine in. I ended up welding the nut to the back side of the bracket and cutting the little alignment tab off so that if they ever had to be changed again I could simply lift the motor & unscrew the isolators out without having to pull the whole bracket off. The passenger side bracket is almost damn near impossible to remove with with the axle beam in place lol.
BlackBII
Ranger Custom
Truck of Month
982
UT
Yeah, these are a royal pain in the ass. Why couldn't Ford just make them easy to unbolt? :icon_confused:
I'll have it back together in a few days and be ready to hit the trails again.
BlackBII
Ranger Custom
Truck of Month
982
UT
New intake manifold gaskets
New fuel pressure regulator
It's all back together and driving now. Time to hit the trail. :icon_thumby:
BlackBII
Ranger Custom
Truck of Month
982
UT
Some STX livery
BlackBII
Ranger Custom
Truck of Month
982
UT
Looks decent :icon_thumby:
