black rtv vs ultra grey or?
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
I searched all over and didn't find any opinions on the subject of which is the better sealant , so, what do ya'll think is the better sealant and which would you use for different applications ie: oil pan gasket or trans pan gasket or other applications where anti freeze or petroleum products would be an issue..
Also, would you use a paper or cork gasket in addition to a sealant?
Don't know exactly where I should post this question , figured this was good as any..:dunno:
Dune Runner
Alpine, Ca
I generally use black. Gaskets depend on what you are sealing. For instance 3rd member cover I use none. Next time you are in an auto parts store read the packages. They say right on them what they are for. Fuel resistant ect. I also use 3M super weather strip adhesive for a lot of stuff. Also known as Gorilla snot.
scotts90ranger
4,373
Dayton Oregon
2.3 Turbo
I use ultra black for pretty much everything with great results as long as everything is clean, I think the ultra grey is the same deal on being universal...
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
We use ultra gray for everything at the dealership.
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
If thats the grey stuff yup
Kirby N.
Truck of Month
78
Monument, CO
On differentials I just use a gasket and put it together dry and clean.!That way I don't have to scrape the rtv off next time. They seal up nice.
ridgerunner
Tioga County, PA
X2, I used a "Lube Locker" reusable gasket on my rear diff.
DRF
Ardmore, AL
2.9L
Get Up, Move Forward!
I find Permatex Ultra Blue works great on most oil applications(valve covers and oil pan, etc...), and water applicatiins(water pump, lower intake seals). I won't use regular RTV for anything. But I prefer to use a Fel Pro Permadry gasket whenever it's available. No sealant and always works, not to mention being reusable. On a rear end I find that Ultra Blue works well too, the only drawback is its light blue, and can stand out if you aren't careful with it or trim it off.
DRF
1992 Ranger 4X4
Ardmore, AL
dsltech83
ASE Certified Tech
So Il
You guys using the stuff that says "for 7.3L engines" too?
There are two types of Ford grey. Ta-29 is the ultra grey stuff. Ta-31 is the IH specific stuff for 7.3 powerstrokes.
