bizarre cel codes (from scanner not flashes)
nesralyrrej
Arvada Crawlarado
4.0 s/c
Make it fast, Make it loud.
my scanner came up with codes;
14 Profile Ignition Pickup Circuit Failure
19 Failure In PCM Internal Voltage
Erratic RPM During Hard Idle Self Test
RPM Drop Too Low During ISC Off Test (1.9L EFI)
Power Processor Check (2.3L HSC EFI)
Cylinder Identification Sensor Input Failure (3.0L SHO)
22 Manifold Absolute Pressure/Barometric Pressure Sensor Out Of Self Test Range (i believe it doesnt have a map sensor..)
23 Throttle Position Sensor Out Of Self Test Range
39 AXOD Converter Bypass Clutch Not Applying Properly (uhh front wheel drive only?)
47 4 X 4 Switch Is Closed (its 2wd)
Measured Air Flow Low At Base Idle
so um whats goin on? again this was from my very expensive scanner
Which engine?
nesralyrrej
Arvada Crawlarado
4.0 s/c
kimcrwbr1
46
maplevalley WA
2.8l
Have you gone through and cleaned all the wire connectors good with electrical cleaner and put back together with dielectric grease. Sand all grounds metal to metal. Look for cracked bare or broken wires and fix as necessary. Especially around the manifold/s. Allways address the lowest number first clear the memory and reset the computer by disconnecting the battery for 1/2 hour. Any time you clean or change a senser clear the memory and reset the computer to confirm the repair.
nesralyrrej
Arvada Crawlarado
4.0 s/c
its throwing codes for things it doesnt have
