Big problem, need advise.
Stang_guru
Virginia
Big problem, need advise. UPDATE.
First things first. 2001 Ranger XLT 4.0 4wd.
The last 2 years I've had lots of brake problems. It started at the rear with both rears seizing, causing me to have to replace both drums, cyliders, pads, and springs. $300 later and I was back in buisness.
Fast forward to recently where the front brakes started acting up. Heres whats going on. Speed must be about 10mph or so and higher, wont do it while stopped. Get moving, turn to the left, (any bit from left of center, max or minimum doesnt matter), hit the brakes and the peddle pulsates and drops about 4 inches and there is NOT much braking happening, slight slowing, but have to grab them again to get stopped well. Down right scary.
Will not do it at all if turning right or straight. ONLY LEFT.
New pads front and rear, all checked, there fine. I've ran 4 bottles of fluid through the lines and know there isnt any air in the lines. NO leaks what-so-ever, checked for a week on concrete after multiple runs checking the area I drove and parked, no leaks. NO broken or pinched lines, checked while the wheels were turned in all directions. Everthing looks a-ok. Fluid levels are fine. I keep maintenance on my vehicles very strict, and have been threatened divorce for the amount of time i spend taking care of them lol, but parts fail even under those circumstances sometimes.
It only does it while turning to the left. I'm at my wits end here lol. I'm thinking master cylider maybe. What do you guys think? Snows coming and I need brakes fast lol. Any help GREATLY appreciated guys.
thegoat4
6
Disable your ABS (pull fuse) and try it.
Stang_guru
Virginia
Ok, i tried that and immediatly noticed the pulsating AND spongy dropping pedal problems went away. pedal stayed firm and at the top and brought the truck to a stop with no need for any extra pumping effort like before.
I pulled the #6 fuse under the hood for the ABS Pump, which in turn tripped the ABS light on the guages as expected. drove it around for a while and it seemed fine again. i then replaced the fuse to confirm and the truck stayed ok while the light was still on. after i shut it off and re-started it, the ABS light was still on but driving normal, but after about 3 minutes of driving, the ABS light went OUT and the braking problems returned to spongy dropping pedal with very little force again. immediatley pulled the #6 fuse again and the brakes returned to normal operation confirming some problem there.
so, is my ABS pump failing completly, or is it failing from another source? and where can i find a new one and the average cost?
thanks for the help, its been extremely usefull.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
I would say the problem is more likely a faulty ABS control module.
AD
swamprat
lexington KY
My wife had an Olds that did something similar like your truck. The front end would shake violently at slow speeds. She thought that the front of her car was going to fall off. She also had very litttle brakes when this happened, they would go to the floor. It turned out to be a sensor on both calipers that was bad.
thegoat4
6
AllanD is probably right, but before you replace it, inspect all of your sensor wires. If you know a good mechanic it'll probably save you money to have him check it out since he can troubleshoot individual sensors before throwing a module at it.
For me on my vehicle, all brake parts are dealer items.
