Better Deal?? Asap
MUDDING B-3000
Barrie, Ontario, Canada
Ford , Ford
7.3L , 4L
ok so i was looking at my local super shopper and i found this guy sell 2 different sets of tires and i need you opionion on what is the better deal
SET OF FOUR GOODYEAR WRANGLER ALL TERRAIN RADIAL TRUCK TIRES.33X12.5X15, USED 3 MONTHS, APPROX 5000 KILOMETERS.RAISED WHITE SIDEWALL LETTERING, EXCELLENT CONDITION. $500
BRAND NEW SET OF FOUR HERCULES TERRA TRAC ALL TERRAIN RADIAL TIRES. 31 X 10.5 X 15LT. NEVER BEEN MOUNTED , RAISED SIDEWALL LETTERING. $550
i kno that the 31" tires will fit my truck but not sure about the 33" my truck had a 3" lift on it but i dont kno if they will rub, i will be getting rims with about 3.75" off set so i think that the 33" might fit.
Also i will be doing some mild off roading in a month or to and this truck is my DD to
mhughes165
9
302
33's will fit....31's fit while stock with no rubbing on your style truck, so 33's will fit with no rubbing on a 3" lift no questions
MUDDING B-3000
Ford , Ford
7.3L , 4L
ok sweet ya i want to get them cuz i want a lil bigger tires but do you think stock rims will work or??? i was thinkin i need about 8" wide rims cuz stock are 7" also does any one kno anything about each set of tires? which one would be better
