best plugs and wires?
Stormtrooper
Tyler, Texas
4.0 v6
what is the best options for plugs and wires 94 4.0?
kimcrwbr1
46
maplevalley WA
2.8l
A good bosch wire set and stock motorcraft plugs in my opinion. I also like autolite single platinum plugs.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Use double platinum plugs. Ford uses a waste spark system so you need the double for equal wear (google waste spark system). Otherwise just use copper and change them more often.
I prefer MC wires over Bosch. Performance wise they are about the same but I tend to have fewer issues with the Motorcraft ones coming apart when I take the wires off.
You can usually get MC wires cheap on Rock Auto.
gw33gp
537
Costa Mesa, CA
4.0 SOHC
33"
I also like Motorcraft wires (from Rock Auto) and use Autolite Double Platinum plugs.
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
You can get the Taylor thundervolt wires. Idk how worth it they are but I can verify that they have much less resistance than other wires, my ohm reader said the ngk wires I had were at about 1500ohms for each wire. The Taylor's were at 100ohms. Pretty good imo.
Use either iridium or double platinum auto lite or motorcraft plugs.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Yes, I agree. I've found they don't leak spark as much as the Bosch wires as well. I've felt the Bosch wires are a one use deal.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Oh, and Autolite and Motorcraft plugs are pretty much the same deal. They are both made by Honeywell as I recall.
