Best height for pillar gauge pod?
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
So, I received my order from GlowShift yesterday, with an OP gauge, coolant temp gauge, and pillar pod.
I already know that my grab handle has to go for this install, which I'm fine with. The question now is how high do I mount it?
If I mount it lower, it's easier to see when looking at the main cluster, but it blocks part or all of the window defrost vent.
If I mount it higher, it's farther from the cluster and my general viewing direction, but won't block the vent.
And of course everything in between.
So, any advice? And also, I know both @Manscout and @Uncle Gump have pillar pods in their trucks, if they would post pics that show where they are on the pillar, that would be phenomenal.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,631
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I didn't have a tape in the truck...
But it's about two opossum tails down from the upper handle boss on the a pillar trim.
Or about two fingers below...
And two fingers above the dash...
It keeps enough air moving across the driver glass to keep it clear for me.
RobbieD
2.9l Mafia
3,594
Georgia
I assume that the fingers are Standard; is the possum Metric or Standard?
Uncle Gump
Token Old Guy
13,631
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It speaks Romulan... so however they measure.
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
Uncle Gump
Token Old Guy
13,631
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It is definitely middle.
I bought a GMRS radio mic zinger and I'm gonna try to install from the top handle bolt. If the mic flops around banging into stuff... I'm probably gonna use it for a go pro mount of some sort.
CamTheHedgehog
ASE Certified Tech
422
Charlotte, NC
Ranger Edge
4.0 SOHC
Oooh... I like that idea. I may have to borrow that. Especially for when I venture up midwest this summer, I do a decent bit of trail riding there (it's not just ALL cornfields).
Manscout
143
Gillette, Wy
33x12.5x15
Mine is 1/4" from the dash. I slid it down as far as possible. I can easily read the bottom gauge. The top one is not as direct. I little bit of the bottom of the gauge is obscured. If it were any higher, It would probably be blocked even more. The fist pic shows how far down I mounted it. The second one shows my line of sight to the gauges when sitting in the driver's seat.
