Best headlight?
86ranger4x4owner
2.9l
I got a 1988 ranger 4x4 supercab. And the stock lights just arent bright enough. I don't want to spend a lot of money on HID's but what is the best and brightest light that I can get just to plug in? I dont want to change the wiring or anything. Anybody got any links to websites or anything? thanks.
daniel3507
74
NE Oklahoma
2.3 EcoBoost
Well i would say phillips xtreme power, but thats not an option. You may have to go with sylvania silverstar. And good call on not going HID
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
Install a headlight relays help a ton and a set og Cibie's with some h4 will be really bright
http://www.danielsternlighting.com/products/products.html
stay away form silverstar there junk
86ranger4x4owner
2.9l
So the sylvania sliverstar headlights are no good? Also the headlights I have now are the ones that came on the truck so i dont know what kind they are i know there sealed beams but i took them off and they have one big bulb in the middle and a smaller bulb below but the smaller one isent hooked up is it suppos to be if so how do I hook it to stock harness? i looked some headlights up on ebay that look just like mine and they are hid projector lights.
jhammel85
Guest
I'd recommend against the eBay lights. They're very cheaply made. I don't like mine at all..
Sent from my android tablet using Tapatalk 2
Gary101386
Oswego IL
have you tried the headlight restoration kit form your local parts car...?
86ranger4x4owner
2.9l
Yes i have. The lens are clear. Also am thinking about going with the silverstars. Are they anygood or should i just get a set of brand new of orginal headlights?
daniel3507
74
NE Oklahoma
2.3 EcoBoost
To be honest Im not a fan of any sylvania headlight. They dont seem that bright and dont last very long but from what I was able to gather it doesnt seem like there are a lot of options for your truck.
86ranger4x4owner
2.9l
How hard is it to switch to a composite headlight? Also are hids just bulb that you put in a composite headlight?
4.0B2
151
Walls, MS
4.0 v6
i'm running the lights from LMC and I'm happy with them. I want to find a whiter bulb but overall i like it. they cost more than the eBay ones but they are well worth the extra money IMO. uses a 9004 bulb (i think... lol)
http://www.lmctruck.com/icatalog/fr/full.aspx?Page=63
however, without using their heavy duty wiring kit... i was melting dimmer switches. their wiring kit is plug and play tho.
11
Rural Manitoba, Canada
Why would you say good call on not going HID. It's the most effective light there is...
4.0B2
151
Walls, MS
4.0 v6
illegal in most states
usually blinds other drivers (even when aimed down, yes i know.. i've been there, done that, tried to aim them low enough... without proper housings they blind people)
but yes, the most effective lighting there is. well, that or maybe LED, but that's still expensive.
6.2
11
You said it, without projectors all of that is true yea, but with projectors it's perfectly legal, better on other drivers than halogens, and more effective at lighting up the road.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
an '88 uses GLASS 200mm rectangular headlamps
the Cibie replacements are probably the best made but are "unobtanium" since the importer went out of buisness.
On my 1987 I run the Hella "e-code" H4 replacement headlamps.
and I run "stock" level 65/55w H4 bulbs (Currently Osram brand bulbs)
AD
