Best Donor Vehicle?
The Slider
Castroville, Texas
1972
I am thinking about getting ready to do a 2.9l to a 5.0 swap. I have a Automatic and want to keep it automatic. What is the BEST vehicle to get most of your parts you would need to for the swap?
Thanks!
Chaz.
whwaufmaio
U.S. Military - Active
Stafford, VA
3 inch body
Get to it
I think it totally depends on what you want to do with it. could be totally wrong, but probably the Exploder is the "simplest", I went with the SN95 because it was cheap and available and had the T5 trans I wanted.
Sent from my SM-N950U using Tapatalk
85_Ranger4x4
17,867
SW Iowa
Explorer can get you both engine and trans (2wd's are not common but out there) and rear axle. And are cheap.
SN95 I would suspect you would have to about run into a wreck to get one cheap.
Explorer has a better intake and slightly better belt system. SN/fox/80's land yacht would probably be closer to your truck electronically.
It is going to depend somewhat and what you want to do with it the thing too...
The Slider
Castroville, Texas
1972
I'm not looking for SUPER SPEED. Just something BETTER than that horrible gutless 2.9l.. SO If i find and explorer 4WD (because mine is 4WD) That is the best? Sounds good to me! Mine is a 1986 Auto 4WD.. What year Explorer would you recommend?
Thanks!
Chaz.
85_Ranger4x4
17,867
SW Iowa
I know the later ones have PATS which complicates the swap a little.
They didn't make a 4wd 5.0 Explorer, they were either AWD or 2wd. You can put a '150 t-case on the trans though.
I am not a big guru on late model engine swaps, my truck was original carbed so I ripped the intake and dizzy out of my crown vic engine and slapped on a 4bbl intake and Duraspark dizzy. A fuel injection swap would be a lot easier in your truck.
whwaufmaio
Stafford, VA
3 inch body
Get to it
I converted my H.O to carb, don't like computers and I'm too impatient to go through wiring everything.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
You can have pats tuned out of the pcm with a custom tune.
85_Ranger4x4
17,867
SW Iowa
You are going to be doing that either way. 7 years and I finally got the last of the extra 2.8 wiring out of mine.
Yeah, it is an extra step though.
Craig0320
225
Mississppi
It is not that big of a deal when everything is an extra step installing an engine into something where it wasn't originally supposed to be. :D
BlackBII
Ranger Custom
Truck of Month
982
UT
95-97 5.0 Explorer won't have PATS, and it already has the compact accessories that will fit more easily in the Ranger engine bay.
You could also consider a 4.0 swap; it will bolt into the place of the 2.9 and give you more power.
85_Ranger4x4
17,867
SW Iowa
You have to send it off and they do it and send it back... its all greek to me. :icon_twisted:
96-97, 5.0 wasn't available in '95.
First gen Explorer would be a good donor for a 4.0. You get the engine, trans, t-case and both axles out of one carcass. Possibly bucket seats and console too if you are so inclined. For a second gen you lose the front axle but everything else would be similar for interchangeability. Avoid the SOHC, in addition to reliability issues it is a more complex swap into a first gen.
I think I have heard rumblings the 4.0 is kinda different going into a first gen too, not as nice as going into a second but not impossible either.
