Best chip
Billyfl.
34434
Ford ranger xlt
What is the best performance chip to use in a 93 Ford Ranger 2.3 single overhead cam D port ??
gaz
672
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Billyfl.,
I have used both Hypertech and JET make both stage 1 and 2 CHiPs for your truck. There is a hitch, they no longer support or produce them. Summit Racing and JEGS still carry their CHiPs for many models and they can be found in the secondary market.
Billyfl.
34434
Ford ranger xlt
Ok so what is it i need to look for to make sure It's one that will work right ?. It's a 2.3
racsan
4,497
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I vote for pringles
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You could just give me your money. That way I can go buy something useful like whiskey and chicken fingers. Either way the result is the same on your end. You have less money and your truck will work exactly the same.
Billyfl.
34434
Ford ranger xlt
Basically they're all the waste of money what's the best way to get horsepower ? Without going Turbo
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Supercharger?
Blmpkn
Toilet enthusiast
6,375
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
That wasn't a joke sadly. To gain a meaningful amount of power from a 4cyl motor you need forced induction, or a rotating assembly and head setup that will spin many many more rpms than factory.
Either way, loads of work.
Billyfl.
34434
Ford ranger xlt
Well thanks all . guess ill look for stroker kit . and boport head
gaz
672
Wa, Bremerton 98310
Billyfl.;
First things first, I NEED TO IDENTIFY MY GOAL(s) to get the correct path to follow. I am a fuel economy nut, so my goal with your engine would be simple; to make it more efficient where ever I can, resulting in the highest possible fuel economy.
The first thing I would do is learn how Ford made 14 more hp with the 95 version and decide if that fit my end goal, then incorporate it.
To date, the single largest power robbing fixture I have identified is the crankcase driven fan/clutch; remove that and install a 16" puller with a new water pump.
If you aren't already, incorporate the use of all full synthetic fluids; engine oil, transmission fluid and differential fluid.
Your engine has, is and will continue to be used in racing, resulting in a ton of after market support. Back in the late 80's there were 10x the number of companies making parts for it over the Cologne V6's.
As divulged, my focus would be on fuel economy, so I would dig into the parts archives and try to learn which parts helped make them more efficient.
Here is a link about building your SOHC Lima I4 engine for power. Some of what is done may be of interest as well as the resulting 268 hp at 211 ftlbs of torque.
Like I said, I don't know what your end goal or budget are so maybe that's something to think about ..)
