Bed leveling?
97LowRanger
Irving Tx
2.3 L
So ever since I've had my ranger its had a dent on the left rear side of the bumper this caused my bed to deform a little now that its lowered 4/6 you can really see it I was thinking of using washers at the bolts to level it but im concerned with its integrity? If i can do it Id like to got to 16x10 steelies and run 225's to be stretched and roll the fenders and bed sides similar to his truck which i love, http://www.therangerstation.com/forums/showthread.php?t=120245&page=3
XLTsplash
160
CA
2.3L
I leveled a lot of Ranger beds on new Rangers when I was working at a Ford dealership. I think body and bed lean was the most common warranty problem I fixed on them. For the beds I just used large thick fender washers. Washers between the bed and frame won't cause any problems and it's a cheap easy fix.
97LowRanger
Irving Tx
2.3 L
Thanks a lot! will do that soon, its almost 1/2" is that still ok?
XLTsplash
160
CA
2.3L
I wouldn't stack a bunch of thin washers to get the 1/2". I would use two 1/4" thick washers or you can just look for some metal that's the thickness you want to lift the bed.
