Banjo bolt to fitting question!
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Guys, I ordered stainless braided brake lines, description says 10mm banjo....I just realized my banjo bolts are 3/8x24.....I can reuse my bolts......but will the actual banjo fitting still work or is it different for 3/8??
As long as the bolt fits in and the crush washer is on the sealing surface you should be good.
ericbphoto
Overlander in development
16,706
Wellford, SC
3.0L
6"
3/8" and 10mm are close enough that it should work fine. Having the right threads is the important part, plus good crush washers. Some recommend always using new washers. I have re-used them many times with good success.
This message composed solely of recycled electrons. Go green!
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
To put the "crush" back into copper gaskets, heat them up red hot with a propane torch and drop them into water. You will be able to bend them with your fingers easily if done right.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Thanks for the advice guys! I did go back to the order and it does state 3/8-10mm banjo fitting. I have never heard of heating them up Always, I guess you're basically annealing the copper huh
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yes, it is annealing the copper.
ericbphoto
16,706
Wellford, SC
3.0L
6"
Thanks for the edumacation! I mean. I do buy new ones every now and then. They're cheap. But if the old ones don't leak, they must be good enough.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
Most hardware kits come with new washers. I know some people who refuse to use the new ones and some people refuse to reuse the old ones. If it were me, I would use the new ones and save the old ones. I put my old ones in my toolbox I keep in the back seat. They wont get lost and they are in the truck if I need them. However I never had a new one leak. Just make sure you clean the surface area really good with a soft wire brush and brake cleaner and you will be good to go.
