Are you doing it yourself or taking to a shop? You save HUNDREDS if you do it yourself. I found the kit on Ebay for $70-100 depending on which one you get. The complete kit has upper/lower ball joints, inner/outer tie rods, and sway links. If you take it to a local mechanic I would expect the bill to be around $300-400 for upper and lower ball joints. Dealership will be about $500+ and they will try to sell the tie rods and an alignment too. Don't forget that you will need an alignment after you replace these too. So the question is are you handy? you'd save a lot of money.... $70 for the parts, a nice weekend to do it at your leisure and then about $50-60 for an alignment.
