t0mw
- Jan 1, 2013
- 0
- Ford
I have a 94 Ranger with Mile Marker manual locking hubs. 4wd worked great the few days I used it last week.
Today when coming home from store, I had a lot of vibration & a noise coming from front. Kind of sounded like grinding but not quite the same. Sounded to be coming from right front. Hubs were locked in, but I was in 2wd at the time. Didnt start till I reached about 35 mph. Pulled over & I didnt see anything wrong, unlocked the hubs & relocked them again to see if one was not all the way in.
Continued home, going down hill, hit about 45 this time & a large bump in the road & it started again, same thing as before.
Took it to work, pulled both front wheels & hubs, looked for anything wrong, but didnt see anything, jusat that when I had the tires replaced last week, they didnt seat the o-ring properly & it was cut.
Put it all back together & started coming home, still with hubs locked. Vibration & noise started again.
Went back & pulled right front again, still didnt notice anything wrong, no wierd noises when turning by hand, and the hubs locked in.
Only thing I noticed was some play where the axle goes through the spindle. All U-joints had been replaced last year, as well as bearings.
Started home again & same thing at 35 mph. Tried putting in 4wd but no change. Got out & unlocked hubs & no noises or vibrations coming home.
What should I look at first ? Hubs, axle, U-joints or differential ?
Since there is play where the axle goes through the spindle, should I look at the spindle needle bearing ?
Oh, fluid was replaced in diff same time u-joints & seals & bearings were done, as I replaced a missing right front axle.
