mudflies
- Jan 21, 2012
- 0
- ranger
Hi ranger folks:
Im looking for some direction. I dont have a lot of money so throwing parts at this is not for me. So here it is: 93 3.0 4x4 automatic. 93,000 km. I bought this truck and drove it home 4 hours. It runs good if youre on the gas but seems to lose speed if its just cruising. I can hear and feel it back firing intermitently if im cruising at say 80kph. It will then run smooth and proper for a bit then more backfire and lose of power. If you floor it, it runs like it should. At low speed it seems like you have to push harder on than gas than you should (not my first ranger) to get up to speed. Also idle goes up to 2500 rpm sometimes when put into park. Flashing cel when back firing. I havent pulled the plugs yet (tmorrow). The plug wires look fairly new. The coil looks stock/original. Motor oil has no moisture in it. Im open to any sugestions. Im going to pull the plugs and clean maf and intake tmorow. Any pointers would help. Thanks.
