back to power brakes
faststang90
dayton texas
ranger
347
I cant get the brakes to hold the truck to get it to stall up very high without it pushing the truck pass the light at the track. I'm going to put the power brakes back on the truck. I'm going to have to run a electric vacuum pump so the power brakes work because the camshaft is too big. hoping to get it to run low 11s in the 1/4 mile. wish me luck lol
alwaysFlOoReD
5,105
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Good luck!
faststang90
dayton texas
ranger
347
thanks, going to try and get everything done so we can make it to the track Friday night
8,371
Drum brakes hold against torque much better than disc brakes
You can raise the brake pedal pivot point, or lower the master and pedals master push rod to give you more leverage, so more pressure at the brake calipers/slaves
Smaller master piston has longer travel but can generate more pressure
Good luck
faststang90
dayton texas
ranger
347
so I went to the junk yard and pulled a brake line off it was on one without that brake box just like my truck so I was thinking it would screw in and its a different size. why can ford leave stuff the same size.
faststang90
dayton texas
ranger
347
its on but the power brakes still does not
its on but the power brakes still does not work. I have a vacuum canister coming the pump says it did not need it but I guess it does. guess I just wait and see.
faststang90
dayton texas
ranger
347
I had to add a can to get the brakes to work right not sure if I could have just added the can or not.
