B2300 towing
scradley
mazda
2 words that shouldn't go together i know haha. So i have a 95 b2300 5 spd with 3:42 gears. Im looking at towing a 2000lb track car on a tow dolly behind it. Already plan on doing a 8.8 explorer diff with 3:73's, new clutch and rear discs from the explorer. Also going to find a tow dolly with brakes on it to help. I figure with car/tow dolly and some tools i'll be looking around 2500lb's behind the truck. You guys think it's do able?
Lifted2x
Medford, OR
I had 89 4x4 with the 2.3 and pulled about the same weight that your looking at and it sucked. I would never do it again, didn't have the power, brakes and it took its toll on the clutch. Plus most tow dollies don't put much weight on the back of the truck so its really going to push the rear end around.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I did this 160 miles across Michigan, including some stints on the highway. Though, it WAS the middle of the night mind you.
Actually this is an early pic, we had my bed loaded up flush with the rails with stuff to take back to college (yes it did help keep this thing from pushing me around), the front end back on the J10, and the bed of the J10 filled with all the other J10/cherokee parts we didn't put back on.
1997, 2.3L, 3.73's, 235/75R15.
2000lb and 3500lb trailer brakes seem to have the same mounting pattern (brakes include a spindle I believe). Still looking at adding brakes to mine, but I want to run a controller.
I tow a lot with mine. A LOT. You should be able to hit 60mph, eventually, and not uphill. Downshift if necessary, even if you let the engine rev up really high, it'll still be easier on the engine and transmission. Leave lots of room. 2,500lbs is not that bad.
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
if you can find an axle with 4.10 gears, i would think that would help quite a bit. letting the gears do more of the work should make it easier on the rest of the drivetrain, esp. the clutch perhaps. most important will be the braking. the manual tranny should help there lots. challenging, but doable for sure.
just my $.02.
TheTopher
176
Delaware
2.3
I've got a '95 2.3 myself and the manual says with 4:10 gears 2000lbs is the max recommended towing load. For the 3:45s we have it says "Towing is not recommended" :icon_rofl:
I wouldn't bother too much about getting an 8.8 axle. It wouldn't hurt, but I've found that unless I'm doing something VERY stupid (Which I have not done yet, thankfully) my engine's going to stall way before I start breaking driveline components. I say just focus on those 4:10s
I'm quite certain you have no such thing.
Ford never put 3:42 gears in the Rangers. I don't think anyone ever even made such a ratio.
Captain Ledd
39
Michigan
302, 2.3
My friends light 3/4 ton Chevy 2500 Silverado has 3.45 gears in it. I have personally checked. Close, but not 3.42.
I have never heard of a 3.45 offered in Rangers though. Ford's usually just went to 3.55, or 3.31 (sometimes 3.27)
scradley
mazda
sorry guys 3:45's. read it wrong.
ya i have the same manual i got a laugh
Junk Collector
Truck of Month
4,806
Rapid City SD
Old thread, but FYI. 3.45 is pretty common. My '86 came with them, and my '96 has them as well. I have had a few other RBVs with 3.45s as well, but 3.73s have seemed to be the most common.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
i have 3.45's, its miserable towing over 1000lb
donfordguy
my 83 had them 3:42 and it says it in manaul
