Average mpg?
Rusty Bouquet
36
Portland Oregun
Ford Ranger xl
What is considered normal mpg for the 3.0 4x4 with an auto (unknown mileage, but gotta be over 120,000))? Thanks!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would say just short of 20mpg is you drive it decent.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
17-18 mixed 20 in decent terrain.
Rusty Bouquet
36
Portland Oregun
Ford Ranger xl
Then I have a little room for improvement. Might need to put a stronger return spring on throttle too, I can barely fell any pedal resistance, so I tend to launch her sometimes...
Josh B
1,987
Oklahoma
Is that you in the picture Rusty B ? You look a lot like my little brother
Uncle Gump
Token Old Guy
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'll admit... it was hard not to call you out on the mullet... but I refrained. lol
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
3.0 with auto trans is the worst gas mileage combo ford made for rangers in my opinion. I have a 99 3.0 2wd with auto trans and I'm lucky to get 15-16 mpg. Maybe 17-18 if I'm on the highway. Being 4wd it should be worse than a 2wd. That's my input.
Rearanger
23
Southeast USA
Before electric fan was getting consistent 18+ to 20 (usually 19), easy driving on paved country roads. With e-fan I'm getting 20 - 21.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
650
Central Indiana
17-20mpg is most common:
But that's including 2WD trucks and manual transmission trucks. The Auto/4wd combo is going to be near the bottom of that bell curve.
For your lack of throttle response, the throttle cable is likely stretched out. Search for the "zip tie mod" for a cheap, easy fix.
91stranger
512
Gets Mo Chicks
Zip tie mod is easy and it works good. I have a few of the small zip ties on mine and it felt like the truck got a good tune up when in all reality it is just getting the correct amount of throttle whereas before when you put the gas pedal to the floor it would be about 3/4 open at the throttle instead of full throttle. Takes about 2 minutes to put some zip ties on to get correct throttle response.
Josh B
1,987
Oklahoma
I write down my mileage every fill-up, and figure it every next one, it does a lot to show active or pending problems.
Or you can just keep track of gallons added between fills.
First step though is to check the odometer agin the mile markers on a good stretch of interstate
