Granny low is not a "Barnyard gear"
Its a "clutch saver" gear.
Ive used granny low all time in my 78 when starting off with a heavy load. Not that i couldnt take off in second i just dont see the point in doing that to the clutch. You can shift out of granny 1st while rolling. You just cant shift into it (unless you double clutch and pray)
Also, most of the 4sp granny lows have a low reverse gear as well, which really saves the clutch when trying to back a heavy trailer up.
Ill take a 4sp over an automatic anyday. Will the only reason you think an auto is better is because you have one. Dont get me wrong the TH400 is probely the best or second best slushbox ever made (Rivaled only by the C6), but i have seen automatics grenade when used hard, with a stick shift you'll lose a clutch first, which is better then losing the whole tranny.
for me, with a 26% grade of a driveway, when I pull into my drive off the road it's in second. I head up the drive and it downshifts to first. Than, the trailer starts to load the truck, it slows and the converter starts its magic and it starts up the hill. You can be at a dead stop, 14,000# on the motor, push the pedal to the floor, converter starts working and it starts moving again. No low-range or anything. It's not magic, it's not nursing the clutch. Its the converter.
Its not the converter. Its the low end torque of that 6.2L letting itself be known. I gurantee with my 78 Ford with the T18 i could do the same thing from a dead stop, the only time i would be at a disadvantage is if we both started up that hill in second gear, cause your auto can downshift to 1st on a roll, my 4sp cant (unless i get lucky), in that case ill floor it, open the secondaries, and that old 400 will grunt its way up the hill.
With an automatic you dont really get full lugging abilty of the engine. Its really limited by the holding power of the fluid, clutch packs etc. With a stick shift its limited by the clutch, but i trust a clutch to grab more then a fluid coupling.
Also, to set the record straight, the M5OD does not have the lowest ratio of all 5sp trannys in rangers, the TK5 does with a 3.96 1st.
Truthfully, i think O/D in worthless in a work truck. Your not supposed to pull anything in that gear and if your using the truck the way it was ment to be used then you dont use that gear anyways and most O/D autos are weaker then there 3spcounterparts.
later
Dustin
