At my wits end!
maroon93limited
Taber, Alberta
So, 3 4x4 modules and 4 switches later, I still have no 4x4 in the Explorer. No light at the switch, module test says it's ok, not one bit of clicking or other noise. I have a brand new shift motor waiting to go in but is there anything else I should check? Last time I checked the fuses they looked fine, but I could always replace them just in case.
Am I not getting power to the switch or something? I swear that if I get under this thing, put the new shift motor in and still nothing, I'll burn it to the ground! No 4x4 for two winters now is getting a little tiring.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Check power to the switch. If thats ok check power from switch to module.... Power from module to shift motor...ect...... Or re-wire from power to switch to motor..... Or swap in a manual case and never have an issue with it again.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I'd look for a manual transfercase like BDAB stated. You'll have a lot less head ahce.
Earl43P
38
Farmington, Pa
Ford F250 4WD
unoleisu
6
Stillwater, Okla
2.9
I agree with Earl43P....and if that don't work, instead of burning it to the ground...I'll take it off yer hands.....:)
Just sayin...let me know :)
06RangerXLT
54
Georgetown Ontario
get out your power meter and find where you lose power.
maroon93limited
Taber, Alberta
Sweet damn deal! Put the new shift motor in tonight and BLAMO!!! The 4x4 is working just fine now. I was sure I had a break in a wire or something, but nope, a burned out shift motor can cause no lights at the dash and no noise from the module. Most satisfying clunk I've ever heard coming from a vehicle!
