- Oct 21, 2008
- 68
- Sacramento, Kalifornia
- Ford, BMW
- Engine Size
- 2.9, 4.0
Suggestion? Buy mine.bump...
looking more into building my own. come on guys... give me suggestions.
would like to start w/ a lower.
i want 5.56. 16" barrel. simple build.
You want to start with a lower? A lower is a lower is a lower. Find one with a roll mark that you like and buy it.
For an upper look at http://www.jsesurplus.com/ They usually have pretty good prices.
When looking at uppers/barrels think about what chamber you want.
For .223 there are 3 common chamberings.
5.56 NATO Chamber:
5.56 load is hotter than .223 Remington loads. A 5.56mm chamber is not as tight as a .223 Remington and will take the brass expansion and higher power load of a 5.56mm round. They are generally less accurate than a .223 chambered gun.
.223 Remington Chamber:
The chamber and throat are very tight and usually are more accurate. DO NOT USE 5.56mm Ammo in a .223 chambered gun.
.223 Wylde:
A hybrid of the .223 and 5.56 chamber. It has a slightly larger chamber and throat than .223 but not quite as open as a 5.56 one. .223 Wylde (IIRC) was made to shoot hotter loads in match grade guns. You can use either .223 or 5.56mm ammo in a .223 Wylde. A .223 Wydle is generally as accurate as a .223 chambered gun and more accurate than a 5.56 chambered weapon.
Then of coarse you have specialized chambers such as .223 Ackley Improved and wildcats based on the .223 such as 35-223, and 300 Whisper.
I run a .223 Wylde chamber.
-Jester
