an idiot needs some help
19cobia
hampton VA
2.9
OK im the idiot that needs help my 87 B2 has a bad rear end it has 373 gears i have a friend 8 work with that has a 89 b2 parts truck with the same gear but has limited slip that i can have free but it has the strange rear drive shaft and i have the normal ujoint shaft what is involved in swap or can it even be done
shortzt
they both should have a u joint on the axle end, the only thing is the 89 might have a big flange, its worth getting for free you can make it work, if your flange doesn't fit you can get a new one or grab one from a junk yard
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Grab the free one and put whatever you need on it from your old one.
19cobia
hampton VA
2.9
Ok so everything from my axle will fit it :D
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Should all be bolt-on, plug & play. I'm not aware of any differences in BII rear axles other than later ones having the ABS tone ring and sensor in them (I think '87-'90 axles).
And the dual-CV BII driveshaft has no u-joints, it's a CV at both ends.
sgt_apple
CT
4.0 ohv
you're cooking with fire as long as its not abs equipped (even then it can be worked around) lsd is nothing but a step in the proper direction and if the flanges dont match you can make it work with a little elbow grease. well worth the cost for the free rear end
