alwaysFlOoReDs' second try
Spede Demn
Irricana AB
'85
2.8L
You had a busy weekend it seems, lookin good.
You could come and pull the tank out of the rusty blue truck, Im hoping to get it in the shop and start tearing it down in the near future anyway, dont believe I need the tank, and I should have all the tools here for the job, tow bar is already on it for moving around. Im usually home fri, sat, and sundays.
BabyBronco89
GR Michigan
95' 4.0 OHV
looking good it will all be worth it in the end, i wish my b2 was that solid
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I finally got a little time and the weather is decent. I don't have a shop or garage to work in anymore so I'm weather dependent nowadays. I did buy a 10'x20' garage in a box but it turns out I don't have the room to put it up without covering up the sidewalk. :bawling:
I screwed the rad support back on. If anyone decides to do the same, pre-drill the screw holes with a 3/32" bit and if using a cordless drill with torque adjustment go with a 16 out of 20 for torque. I busted a bunch of screw heads off before it finally clicked [pun intended] to turn down the torque on the drill.
Some pics to follow.
Richard
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
sent while sitting on the throne
