- Apr 3, 2008
- 3
- Age
- 49
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
I am thinking outside the box and trying to come up with a power supply/onboard welder. I found a small 80A inverter stick welder that weighs only 8lbs. It will take 2400 Watts to run with an inverter and I cant find a reasonably priced one that is up to the task. The 2000 watt/4000watt peak unit Harbor Frieght has says that the 2k watts must be ramped up and not instant...not sure what the standby amps would be and how fast they would peak with the welder. Has anyone seen a way to convert a second alternator to put out 120V @ 60Hz and possible of doing 20A? Is it possible or was this a far fetched idea?
I just cant see spending $800 on a Premier Welder or even more on a Mobiarc.
