ben_2_go
- Aug 24, 2007
- 340
- Third rock from sun
- Furd
- Engine Type
- 2.5 (4 Cylinder)
- Engine Size
- 2.5 Scrap
- 2WD / 4WD
- 2WD
- Tire Size
- 235-75-R15
- My credo
- None at all.
I had to jump start my '01 Ranger,and it fried the diode.I took the truck to my local auto parts house and had it checked.It checked out as low charging 13.5v and bad diode.The battery was charged and checked out in the high range of good.So, I replaced the voltage regulator in the alternator.Now I have no voltage loss when the truck is off.When I start the truck,my multimeter shows that it is charging at 14.2v.When I turn on the lights and heater blower,it drops to 13.5v.When I shut everything off,it remains at 13.5v.Running the engine up to 2000rpm doesn't make a difference.It holds at 13.5v.I checked my cables and they are fine.No rubs or bare places.The cable battery clamps are clean as well as the battery posts.Should I replace the alternator or is there something else I should check?
