Aligning Headlights DIY
mitch546
just bought new headlights and need to align them properly but i threw out the DIY instructions,. anyone have a DIY for it by any chance?
IE: how far to park away/ what height they should be apart and above the the road etc
flyingbrick
Winnipeg, MB, CA
Someone else can probably give you the numbers but i always went to an empty road that did not have lights and play with them till you find something that works for you, helps if you have a friend that can drive past you a couple times to make sure there not blinding to oncoming drivers.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I usually just aim so you can see the lo-beam hit the road about 2-3 car lengths out, and make sure they're both even up/down, and side-side.
mitch546
i adjusted them just in the driveway cause they were literally pointing straight @ the ground not even half a car length and now their about car 1/2 but id like them a bit higher especially with no fog lights so were gonna tryer again tonight.
I found the lights that came with the headlights are TERRIBLE :mad:, so i might swap the stocks in for now. What headlight bulbs are you guys runnin?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Plain DOT 9004s (9007s in my Ranger). Sylvania or GE brand... I forget which
I run both auxiliary fog & driving lights that are tied in with the lo & hi beams (respectively) on relays for extra lighting (provides far more illumination than with high-power bulbs in the headlights themselves).
mitch546
i had sylvanias before and they seemed to work fine. Are there any bulbs super bright without paying 40.00 a bulb? i know they sell like H1 bulbs or something just want a factory replacement until i get some fog lights installed
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I've seen bigger bulbs advertized in the JCWhitney catalog for like $15, although again, I wouldn't bother, the light increase is maybe 1/3 what you get with a set of aux lights.
For factory replacement bulbs, just stick with a known good brand name.
Once you get the foglights installed, you should have plenty of light.
dogboy
14
Enumclaw/ Carbonado, WA
'93
I did mine myself.
I don't really know what I have for the height... I just parked in front of our garage and aimed them.
I decided to have the right hand light point over twords the shoulder slightly and up a little more than the drivers side light. That way, you are getting a view of what may be by the side of the road, and up a ways while not blinding other drives and still being able to see, yourself.
