form
there is a simple form you send AFT.Because of ATF regulations, you will need to add a little bit of gasoline to denature any alcohol you have sitting around. Just 2 to 5% is enough to do the trick. This way, if you ever do get a surprise visit from the ATF (since they know about your still because of the Fuel distillation permit you took out), they can see right away that you are making fuel, not drinking alcohol.
"I also saw the opportunity to collect wasted corn meal, oats, wheat, and other grains that leak out of cracks in the hammer mills and fall on the floor.
The powder piles up 2ft deep in about a month.
I'm thinking of offering to clean up the mill once a month for $200 and I get to keep the waste.
I'm also looking for damaged or "off-taste" soda pop syrup tanks from local restaurants too.
Thanks,
Mike Powers " THis is a quot from the web page . whats with your intrest in alternate fuels? he ask Well if $3.00 a gal. is not doing it for you Just around the next bend $4.oo and then $5.00 wehre and when will it stop ?
