Aftermarket cooling fan "non electric"
Terry
19
Gardnerville, Nevada
I am thinking that my cooling fan clutch is going out. I want to replace it with a aftermarket fan with the hope that it will use less hp, work better and look better. I looked around and did not find anything on this issue. My current fan is screwed on and the pump has 4 bolt holes to hold on the pulley. Anyone replaced the stock fan? I am also considering adding a puller electric fan on the outside of the fan.
Bird76Mojo
1,265
IL
I used one of the aftermarket fans that spin all the time (no fan clutch) years ago and it didn't help the cooling system at all. I'd either go full electric or stick to the factory fan clutch.
Like this one:
IIBRONCOS
11
AZ
So the good thing about a direct drive fan like in the picture above is it is working all of the time (especially at idle). If the engine is kept at 3000 rpm's or under there is little to no HP loss. Simple and effective. But no fan can fix a cooling system that is not in well maintained condition.
I run a flex fan (one in picture above) in a 1988 2.9 in 100+ degree weather a/c on and idling, and it is always working and cools fantastic.
I have also replaced all other components of the cooling system.
Bird76Mojo
1,265
IL
The flex fan certainly didn't keep my 2.9 from cracking a pair of heads..
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
A flex fan would be a big step down from the factory clutch fan. They may have been an improvement over the rigid metal fan on my '66 Mustang, but that's about it. Why do you think it is failing?
Terry
19
I have a aftermarket temperature gauge. I keep my cooling system is good condition. When it is cool in the morning I can watch the temp gauge drop when the thermostat opens. My system is correctly sealed up and my overflow is at the proper level. In the later part of the day when it is warmer, The temp creeps up to between 185 and 190 while I am driving down the road. It drops down to around 181 to 184 when stopped at a light. This is my second gen 1 2.9 ranger I have built and have had no cooling issues with this motor. My gas milage is still the same as it has been for a long time so I don't believe it is a motor problem.
8thTon
--- Banned ---
806
Pennsylvania
Your thermostat might not be closing fully making it run too cool at idle. Then again i don't know that engine so maybe it's just the bypass.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
the flex fan....on a good day is a piece of crap. but if it is working for a arizona guy then thats fairly significant. they do not pull max air at idle and the fact his ac is working peachy at idle if proof that a low power rbv gets away with one of those things just fine. a v8 or higher power v6 ranger i wouldnt waste the effort.
the oem ranger cooling system is overkill. the plastic hipo fan and clutch are ideal and wont cut you up as bad as the flex fan. i prefer those with stock power. easy to get parts for and very reliable to a point.
