After market ignition
bfiakas
Gilbert AZ
2.9l
Out here in Arizona the heat here is causing alot of problems with my TFI ignition. I ve done a TFI remote to a heatsink,but I am still having stalling issues. My queston is, what is a good ignition system I can totaly replace the TFI with. Also I have two extra stock horns from another B2 to use them with the 2 that are on mine now.Do I have to get a higher amp rated relay? or can I use what the factory put in?
kimcrwbr1
46
maplevalley WA
2.8l
Where did you mount the remote heat sink and did you use alot of the grease. Did you clean the IAT or run codes, I think your hands are tied as far as ignition no way to control the advance without the computer. The best heat sink is for a CPU out of a computer one with alot of fins, if the TFI got too hot it needs to be changed. The horn relay is just a switch I would say maybe a higher amp fuse unless you have a wire size issue. Stuff you probably already know just throwing it out there someone here will chime in be sure and reset the computer if you clean/change any sensors by disconnecting the battery for 1/2 hour.
kimcrwbr1
46
maplevalley WA
2.8l
Maybe lower resistance wires to the TFI (thicker guage) and mount in front of the radiator or out of the engine compartment.
Junk Collector
Truck of Month
4,839
Rapid City SD
I believe either MSD or Mallory makes an aftermarket TFI module and possibly some other stuff too. I also seem to remember that some Mustangs, or maybe it was T-birds... I dunno... already have a remote TFI module. You could probably snag one from the junkyard and run that.
BlackBII
Ranger Custom
Truck of Month
982
UT
Get yourself one of these:
bfiakas
Gilbert AZ
2.9l
I got 2 heatsinks from the JY from a Areostar and put them together back to back and butter with dieletric grease and appled grease as per what the tech section said for the TFI. I mounted the the unit down low on the right fender apron in front of the air intake hole. I took a temp reading of the heatsink and was 140 degs. and TFI was at 100.I cleaned IAT and no codes.I thought of putting in a computer heatsink fan on it or some type of 12V fan on it or just move to Alaska ! Thanks for the info
