adding AC Compressor.
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
looking to add an AC compressor to my truck, use for OBA, is it a seperate bracket or will it incorp. both the compressor and PS pump mounts into one bracket? Any pics of one?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
There is a braket that blots to the back side of the PS braket. I took the A/C braket off my truck because the engine I put in had A/C and my truck doesnt.
Have you set up your cooling system for A/C, basiclly a dual core radiator and a suround fan shroud?
NMB2
22
Cody, WY
5.0 V8
my truck has a 3core and 2400cfm electric fan. I'm not adding AC to the truck though, using OBA.
so the bracket i need will bolt onto what i have currently, correct?
dangerranger83
54
Lafayette, IN
Heres a picture of the braket.
[/IMG]
You said something I've never heard of. Whats OBA mean, damn do I feel stupid. You live you learn.
NMB2
22
Cody, WY
5.0 V8
on board air. using the A/C compressor as a compressor to an air tank.
thanks for the picture. so basically decompress the system, cut the lines off, cut pigtail and 2 bolts and the thing is out.
dangerranger83
54
Lafayette, IN
You got it. The unpainted parts are where it was conected to the PS braket. Cant remeber if it had any other mounting locations.
NMB2
22
Cody, WY
5.0 V8
there was a bit more than just that bracket but I got it figured out, and it was direct bolt in. got the bracket assy and pump for $50 from the j-yard, they pulled it for me too.
so do i need to get a new pully too? has 3 grooves in it i would assume? does the 2.9 pully fit?
dangerranger83
54
Lafayette, IN
The PS should share the same belt as the AC compressor. The grooves should line up. My 2.8 had AC and the main pulley only has 2 grooves, one for the alternator and one for PS/AC.
BTW how did you get an A/C compressor for only $50?? You took them. Keep up the pictures on how you are doing this, I'm interested in doing this in the future.
NMB2
22
Cody, WY
5.0 V8
i just went to a junkyard, guy told me $15 for brackets and $45 for compressor... I offered him $50 for both and he said yes.
this is the tank i have
http://www.4x4groupbuy.com/store/performance-gallon-tank-p-9103.html
and I got a squareD ajustable pressure switch today..
now i just gotta figure out this damn compressor pully lining up.... does something look wrong in the picture i posted? perhaps i will need to put a spacer in that front bolts and move those tabs to the back of the mount, that should push it back a good 3/4"?
dangerranger83
54
Lafayette, IN
I cant remember what a 2.8 looks like with A/C, its been over a year. What did it look like coming of the donar vehicle? Hopefully the compressor works.
NMB2
22
Cody, WY
5.0 V8
it was on a 2.9.....
and the compressor works, already locked the clutch and spun it.
dangerranger83
54
Lafayette, IN
You might have to make it work for you by movig it back the 3/4 of an inch. How do you lock the clutch? Have an A/C problem on a van and want to check if the compressor went bad.
NMB2
22
Cody, WY
5.0 V8
i just took the two wires off of the plug and touched it to the battery positive and negative. locks the clutch.
BLUE BII
1984 and 1997
fords
2.8 AND 2.3
thats a pretty sweet idea for the OBA, might havta go see where i threw the compressors that i took off my BIIs haha
BLUE BII
1984 and 1997
fords
2.8 AND 2.3
so you can jus run the compresor to fill a tank then? Im thinkin bout figurin this out now
