AC wire connection unknown
claya
sacramento
ranger
So I had a guy remove the engine from my 2000 Ranger 4cyl. And he ran into issues with installing the replacement engine, so I am doing it. I cannot remember where this pink/blue fused wire goes. It is part of the AC wire harness, and connects directly to a small relay. Fuse is 15A.
Trying to upload a picture. Will have to follow this post.
Anyone?
pjtoledo
3,015
Toledo Ohio
Fords
3.0 2.3
circuit 883 PK/LB goes from battery junction box, fused & hot at all times to (battery junction box) Wide Open Throttle & AC clutch control relay pin 3. that's all 1 relay.
or so it says in the 2000 manual.
a GY/WH wire feeds the actual AC clutch from the WOT & AC relay.
there should be a diode in parallel with the AC clutch field coil.
