jeffreyott
- Jun 5, 2008
- 0
- Age
- 37
- Ford
So I snapped my timing belt on the highway, 1994, 2.3l, 177k miles, probably was never changed...
Anyways, now I'm trying to get her back in time, and having issues. I've done all the reading, I have the Chitlins book, read all the forums, etc, yet I still can't get her in time (or even get to run rough)
This is what I'm told:
1) Align the key in the crankshaft to 12-oclock
2) Align the stamped diamond on both the cam and the aux shaft (oil pump) with their respective triangles on the back cover. Or alternatively for the cam, line the cam sprocket up with the middle of three white marks on the back cover.
I was able to align the crankshaft.
However, the cam sprocket does not have a stamped diamond on it's rear plate. It DOES, however, have a molded diamond/triangle on the front of the sprocket. There is also no triangle on the rear cover, nor are there three white marks. There are three plastic flanges though...
There is no backing to the aux shaft sprocket, and therefore no stamped diamond. There is, however, again a molded diamond/triangle on the front of the sprocket. I cannot find any markings on the back cover for the aux shaft sprocket.
I have attached pictures, I was hoping someone would help me with this...
* Here you can see the cam sprocket, the molded diamond/triangle on the front of the sprocket, and my three plastic flanges. Is this OKAY?
http://www.cdnuconn.com/temp/IMG_1144.jpg
*Here is my aux shaft (oil pump) sprocket. Again, no diamond (because there's no backing to the sprocket). there is that molded diamond/triangle...but no marking on the rear cover.
http://www.cdnuconn.com/temp/IMG_1147.jpg
*here is my crankshaft key, which i'll align to 12oclock
http://www.cdnuconn.com/temp/IMG_1149.jpg
any ideas? I could really use some help, it's killing me.
Jeff
Jeff
