yes it is 2wd. A little more about the truck: 2.3 with open Speedflow header, 4:10 gears welded, skyjacker double shock kit with nitro 8000 shocks, 1.5" wheel spacers all around, helper springs flipped upside down mounted under the leaf springs to stiffen the rear, sparco rev seat, grant steering wheel, hurst shifter.... plus more but you get the idea. If you wander why in the world i run with the stock ride height and 28" diameter tires, here is why, the truck in this pic is also 2wd but with a little lift and bigger tires.... this isn't me but its a great shot:
by the way he saves it!!
