A different dome light issue
squirrelracing
Alberta Canada
The dome light on my 03 fx4 level II stays on after putting the key in or pulling it out. Stays on for about 5 or 10 minutes until a relay under the dash clicks (im assuming the battery saver relay). Does anyone have any wiring diagrams for this or any insight on this problem? I've been searching around for a couple days and only find questions about the door ajar issue which is not the problem here
Thanks in advanced
8,371
Google: autozone repair guide for your vehicle
Enter in the correct info for the Ranger
They have a pretty good wiring section for the 2003 Ranger
Here is an '01 diagram and should be pretty close
'03 should still use GEM, I think '04/'05 switched to SJB
But interior light relay could be the problem, it is in a box just above gas pedal under the dash, battery saver relay is in the same box.
Also check both Door switches, common issue on Rangers, you would expect a "door ajar" light if that switch was the problem but..........
squirrelracing
Alberta Canada
Thanks thats some wicked info! I think its that relay by the gas pedal I already had to replace the flasher relay there, the little box got some water on it due to the windsheild being smashed out from a rollover
Yeah i had the door issue on my 95, not the case here the chime shuts off when i close the door
Ill do some checkin and post back what i find out, thanks again!
