A/C Compressor Clutch Engages with Heat on...?
97Ranger3.0
67
Florida
4"
33x12.5
Hi everyone,
So I recently fixed my non working A/C in my 1997 Ranger. I had to replace the compressor and got the system recharged the other day and it now works great. This morning though, I went to turn the heat on as it was a little chilly and I thought I heard that subtle 'click' sound when the A/C compressor clutch engages. So I popped the hood, turned all the HVAC controls off, the clutch is not engaged as you'd think. Then I turned the blend knob to full heat and turned it onto the first setting to the right (blowing from all vents) and what do you know, the A/C compressor clutch engages. That just does not seem right to me, I don't see any reason why that should be happening. So my question is, is that supposed to happen? I wouldn't think so but maybe I'm wrong. And if it's not supposed to happen, what could be causing this?
Thanks!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,527
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It is suppose to happen... turning on the A/C is done to dry the air of moisture.
97Ranger3.0
67
Florida
4"
33x12.5
Huh, I didn't know that. I guess you learn something new every day. So my next question then is, does anyone have a wiring diagram for either the HVAC control switch or the A/C system in general? The reason I ask is, I have an electric fan in the truck and when I fixed my A/C I added a manual switch to turn the fan on high speed because I thought I would only need to turn it on when I had the A/C running. So I would now like to re-wire it so that the fan automatically kicks on when the A/C compressor clutch is engaged. I'm imagining I should be able to tap into the wiring that plugs right into the compressor, I imagine one of those wires is the power and one is ground for the clutch. I'll see if I can figure it out with a multi-meter, if not I'd definitely appreciate some advice!
ford4wd08
513
Alcoa, TN
2.8 V6
Also, running the defrost is dependent on the AC compressor too.
Josh B
1,987
Oklahoma
I found on my 93 that just going half-way into defrost will dry your windows and not engage the a/c
