jcrangerboy
- Jul 14, 2010
- 0
- Ford
Just wondering what 5 speed to look for
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
the steering column is optional for the most part. youll just have a useless auto shifter there if you don't get a different one.Big Jim's right. Donor vehicle would be the easiest way to go. Besides the tranny, you'll need at least: computer from manual truck, pedals, and steering column. I'd also suggest the gauge cluster as well.
yes, the ranger clutch system is hydraulic. and all of the holes and access panels for the swap are there, you just have to unbolt them and remove the covers. not hard, but time consuming.the guys are right. Either sell what you have, or get the auto trans fixed correctly, and maintain it. I've done the auto to manual swap in the past, regretted all the work involved. In addition to the computer, steering column (maybe), gauge cluster (maybe), you also need to get a new set of pedals, clutch linkage or maybe the ranger has a hydraulic clutch. Sometimes the holes will be drilled where you have to hang new stuff, sometimes not. If you have a 4WD, there are different safety switches for 4WD. I have also seen setups where the driveshaft is different between the auto and manual trans, either length or different types of ends. I think that the 4 wheel antilock brake systems have a sensor in the trans/transfer case. Trust me, it's a real PITA.
